Will scan it again this week. Had the cluster out and disassembled it. Physically moved needle back to zero. Checked for broken solder connections and engagement of connectors. No faults found. Reassembled the cluster, refitted to vehicle, Speedo needle climbs in steps no matter what speed vehicle is driving at and never returns to zero. However the digital speedometer readout works properly. I'm assuming whatever output drives the meter is at fault. Assuming..... Yeah I know. Never assume anything.
