Hello guys. How do you remove the MAF on a 997 S. The Torx screws holding it in place have a thin rod tha prevents you from using normal torx wrenches. You need one with a hole sto the rod willgo thru. Is this a special tool or can this be bought at a tool supply shop? Thanks
To remove it for cleaning or replacement you will need a Security Torx T20. post-1-029938900 1286117624_thumb.gif
I bought a complete set of security Torx drivers at Harbor Freight for under $5.
Ahh so thats what its called... :thankyou: :renntech:
