I recently picked up a 1999 Boxster 2.5 with 110K on the odo. It had a few fault codes but with a new oil filler tube they all disappeared and the engine runs strong and the car is a hoot to drive (and that's coming from a guy used to quite a bit more HP's) :clapping:
Today we pulled the tranny to take a look at clutch, RMS and IMS.
RMS has a slight leak and will be replaced. Will pull IMS flange to see if the bearing is in good shape. Looking at Jake Raby's stuff, I tried to correctly identify this engine but am a bit at a loss here. The number is (yes I verified) M962065X03247. I found a list of Boxster engine numbers on an Ausi forum (see below), and believe it should match (being a 1999) up with the M96/22 65X denomination.
So whence the difference of M96/20 65X vs. the M96/22 65X?
Joost
Boxster Engine No's
MODEL MY ENGINE NUMBER Boxster 1997 M96/22 65V 00501> Boxster 1998 M96/22 65W 00501> Boxster 1999 M96/22 65X 00501> Boxster 2000 M96/22 65Y00000> Boxster ‘S’ 2000 M96/21 67Y00000> Boxster 2001 M96/22 65Y00000> Boxster ‘S’ 2001 M96/21 67Y00000> Boxster MY02 2001 M96/22 65Y00000> Boxster ‘S’ MY02 2001 M96/21 67Y00000> Boxster MY02 2002 M96/22 65Y00000> Boxster ‘S’ MY02 2002 M96/21 67Y00000> Boxster MY03 2002 M96/23 65300000> Boxster ‘S’ MY03 2002 M96/24 67300000> Boxster MY03 2003 M96/23 65300000> Boxster ‘S’ MY03 2003 M96/24 67300000> Boxster MY04 2004 M96/23 65300000> Boxster ‘S’ MY04 2004 M96/24 67300000> Boxster (987) 2005 M96/25 62500000> Boxster ‘S’ (987) 2005 M96/26 62500000> Boxster (987) 2006 M96/25625 Boxster ‘S’ (987) 2006 M96/25625 Boxster (987) 2007 M97/2065X Boxster ‘S’ (987) 2007 M97/21625
