please help....
while i was parking may (CTT) for around a week waiting my brake booster to arrive i notice an engine oil leaking from the right side so i tried to go under the car and check for the source but i couldn't so i reach my hand under the car and start to take photo and i get shocked from what i saw >>>>>>>
this pic from the right side of the car and that is the exhaust behind the turbo but the leaking is from above i don't know from where>>
can someone help my by identifying the source or which part or what is the problem ??
post-60375-072636000 1286028391_thumb.jp
post-60375-054432500 1286028840_thumb.jp
There are a number of possible sources. If it if on the turbo, it could be from the oil feeder line on the turbo. If it is coming down the block, it could be a leaky valve cover gasket, or a leak in the head from an improperly plugged machining hole.
Take the plastic top covers off of the engine and see if you can pinpoint it from the top.
ok i will try to remove the engine cove and will check if i can see any oil leak .. ,but can i see the turbo from above in this case
thanks,
Edited by cayenne444
