Hi. 'got a 2000 C2. brake lines look fine and the car has always been well maintained. When I bleed the fluid (~every 2 years) it's always pretty clean.
Unnecessary if they do not appear cracked, chafed or damaged in any way. Inspect for bulging or deformed lines which would indicate an internal failure. Rarely does the hose go bad from internal corrosion unless it has had a poor maintenance history. By your description I would say flush the system at its regular scheduled interval and spend you money on something else.
Edited by goldenwarrior1
