It suddenly would'nt shift, but when I'd shut off the car it shifted fine.
I had it flat bedded to Dealership and my Service Tech later called to say the Pressure Plate broke.
Now I just bought this car in April CPO. I'm trying to get the dealer to pay for the clutch as well.
He said it would be a good idea to change clutch as well but i would have to pay out of pocket.
About $400.00 .....Worth it ??
For the 997 Porsche recommends to replace the pressure plate and the disc together (as a unit), because an automatic, disc thickness, compensation system makes part of the pressure plate, in other words, the thickness of the disc must match with the pressure plate adjustment. I would have a talk again with my dealer.
With the motor out already, it makes sense
to buy a new clutch.
I think another name for the pressure plate is the throw
out berring.
I would also get the larger alternator wire installed. The 997-2
has a thicker alternator wire then the 997-1. It is very easy to replace
when the motor is out. The wire itself should be $60 from the
dealer. You could buy one from Sunset for $40 and then
have the dealer put it on. This will improve the hard starting
when the battery gets old.
Paul
