The key fob on my '06 997 S cab broke.
It broke on the side that contains the key blade.
I found a new one on Ebay, unused but with an already cut key in it.
I know how to open the key fob.
What I can't figure out, is how to remove / switch out the key blade. Any ideas anyone?
Patrick
It is a small piece of plastic that snaps
together. Use something small to prey the pieces apart.
Good luck. The 996 site shows you how to cover the trunk
button with tape. Look there if you need more details.
Paul
Thank you,
I will play around with it.
If anyone has more details or (if possible) a pic that shows where the key comes apart from the fob, I'd be most grateful.
  • 4 weeks later...
