I have 2001 with 2.7. When I remove the oil filler cap while the engine is running, the rpm go up about 500-700 rpm. Is this normal?
Not absolutely positive, but wondering if it is difficult to remove the cap? Does it have a lot of suction making it difficult? If so, the AOS may be bad or going bad. I am sure some Boxster experts on here may know more.
I am aware that one check for Air Oil Separator issue is to try to remove the cap while running. May want to check that.
Good luck.
DC
Edited by therock88
