I'm changing the fluid and filter on my 99 996 this weekend. I will be following the DIY tutorial from this forum but I have a question. When I did the oil change the car had to be at operating temperature. Does the tiptronic have to be " warmed up" before I drain the fluid? If so, why? Thanks for your help and suggestions.
The reason is the filling procedure, 40° Celsius. It's wiser, while you drain the TIP. from hot, to let cool down the gearbox till 40° C. than warming the TIP. up till 40° C. with lack of ATF.
