I've noticed a rattle when i switch the engine off. The rattle is not there if i shut down with the clutch depressed. I've found this is normal with a DMF (dual mass flywheel) but as far as i know i don't have DMF. Could this be normal with the original flywheel? Should i be worried? It's a 2003 Carrera 4S btw.
Edited by oyvind
All 996 cars use a dual mass flywheel as a standard, if you can hear the rattling gears loudly, check the flywheel first. If you don't have a dual mass flywheel, as you stated, than is it rather normal.
