Im installing a PSE on my 05 C2, and am a bit confused with reading the TSB on the install...I get the change over valve setup, and the electronics, but am not sure about how those plastic lines are connected inside engine bay, and I have an extra one of 125mm, is that needed?
thank you
Edited by jam996
thank you
One vacuum line goes to each valve on the left and right silencer , these then connect into a Y shaped rubber piece which then goes back to the solenoid valve. The other side of the solenoid valve goes to the inlet manifold vacuum point take off , on some cars this involves another Y piece connected after the take off point , to allow the variocam plus solenoid and the PSE solenoid to share the same vacuum point. On my own car I also fitted a simple switch in series with hte solenoid actuation wiring to allow the PSE to be controlled independently of the car ECU. The benefits are the PSE doesnt go quiet at certain speeds and can be left operational all the time without the need to activate , every time the car is started.
thank you
So only 3 lines, one each for mufflers connected to Y shape and to solenoid valve, and the other from vaccum to U shape plastic(protective tube) on solenoid valve. Right? the short 125mm one not needed?
thanks
The short line probably intended to connect the new PSE solenoid to the existing variocam solenoid so they can share the same take off point for vacuum. Therefore you have 2 braided lines , and two black tube sections.
Ok, got some time tomorrow to finish the install.
I am still not sure if I need it that short line, why is it in the kit then..??
Any ideas?
The routing and attachment of the vacuum lines for a 997 PSE is identical to that of a 996. Here is a link to the description of my 996 PSE install and the vacuum line routing.
I'm thinking of embarking on an interesting project. Could I use the circuit from the 996 PSE to control the 997 PSE changeover valve, so that regardless of the 997 DME setting, I can have a latching switch turn on or off the exhaust (like the 996).
Somehow take the whole circuit with relay, and put that in a 997 to control the PSE. But could I use the Exhaust Button from the 997 instead of the oval 996 one?
Any thoughts/advice?
