Went to change CDs the other day in my CDR-220 and encountered a loading problem. The CD that was inside the unit ejected OK, but I was unable to insert another disc. The edge of the next disk would only go into the slot about 3/4 of an inch.
After examining the ejected disk I noticed a thin black line running across the 'top' side. I pulled out my flashlight and could see a small piece of black plastic hanging down from above, inside the CD slot. It appears to be 'hinged', in that I can pull it forward with a paper clip and it 'swings up' and out of the way. Unfortunately, as we all know, gravity 'sucks' and it falls back down obstructing the disc.
Any ideas?
('99-2.5L-57k)
