I know the issue is with the central locking system. it will not light up on the dask when I click the button. The remote doesn't work, when I lock the car, you can hear it lock and then it unlocks. After about 3 tries, the driver door will lock but nothing else will. The passenger door and the gas flap won't lock. Can it be a mirco switch somewhere or will it be the cpu under the seat since the switch for the central locking won't do anything....I have check the fuse under the seat (good) no water under the seat and carpet is dry, .....any ideas
Edited by zman1858
I had it read at AutoZone and no fault code on the alarm system
An Autozone tester can not read alarm faults. Only Durametric, Porsche PST2, or PIWIS can read and reset alarm faults.
Any beeps when you lock the car with the key fob?
Key fob hasn't work in forever....when you lock it with the key, it beep twice, the clamshell is off the hinges because the cable broke but it's been that way for 1 year, the micro there isn't the issue,,, can a micro in the door cause it not to lock
Edited by zman1858
