Hello,
After I changed the tie rod end I had ABS, PTM AND PSM Failure lights and the car is completely crazy the performance is reduced and as soon as hit the gas it might spin if it was a full throttle, anyone have an idea about this issue? we checked all the sensors and tested all of them and r working fine !
1 day later the PASM was working fine * sport absorbers * as soon as I pressed the sport absorbers to check if it is working or not, it was fine, but as soon as I turned it off I started to have one more failure PASM failure.
The car is 997 Turbo 2008
Any idea guys?
Yeah, there is a steering angle calibration setting (cannot remeber the correct Porsche term) that needs to be addressed (computer reset), it has been discussed before............
OK, found it:
Calibrate the steering angle sensor with the wheels in straight-ahead position!
Note
Check the steering angle sensor actual value with wheels in straight-ahead position before calibrating the steering angle sensor! Only recalibrate the steering angle sensor on the measuring platform if the steering angle actual value lies outside the tolerance or is doubtful!
1. Drive vehicle onto measuring platform. Affix measured-value pickups to all wheels.
2. Check wheel alignment values and adjust if necessary.? If the wheel alignment values on the front and rear axles are correct, calibrate the steering angle sensor with the front wheels in straight-ahead position. Calibration description in following text.
3. Connect the Porsche System Tester 2 to the diagnostic socket.
4. Select the "Calibrate steering angle sensor" menu with the Porsche System Tester 2 in the PSM system. Entry to the PSM system takes place through the ABS system (automatic status change after PSM).
5. Confirm calibration start. The procedure can also be interrupted.
6. The PST 2 now requests the 4-digit safety code shown in the display.
Note
This safety code must be extracted in the Actual Values menu, Safety Code sub-menu! The safety code changes automatically each time provided that PSM is called up again!
The calibration procedure will be interrupted if an incorrect safety code is entered! This time-consuming procedure ensures that the steering angle sensor is not calibrated unintentionally!
The steering angle sensor can be calibrated several times! The value (the zero position) is stored in the steering angle sensor itself!
7. Input the 4-digit safety code with the cursor keys (4 centre keys on right). Then continue with the (>>) key.
Note
The final possibility to interrupt the calibration is not to confirm the safety code input! To do this, press the appropriate function key for no!
Important for calibration: The wheels of the vehicle must be in straight-ahead position
8. Confirm safety code input with wheels in straight-ahead position. Display in the Tester display after the safety code input has been confirmed: Steering-angle sensor being calibrated.
For safety reasons, read out the current steering angle sensor actual value after calibration. To do this:
9. Leave the PSM system. Then call up PSM again and select the steering angle sensor in the Actual values menu. Required display in the Tester display: 0° ± 3° when the wheels are in straight-ahead position.
10. Repeat the calibration if the value is not correct.
