my 99 996 cab with 60k miles has the rear window coming unglued from the top. Top is still in good shape I want to get rear window stiched in to repair. I am looking for a referal of a shop that does this in the Tampa Fl area.
Thanks in advance!
Thanks in advance!
I live in the Tampa area. I don't know any shop which replaces the rear window. I would suggest purchasing a new top with a glass rear window. It is so much better than the plastic and you can use the rear defroster which I used every morning in Tampa. I have a GAHH top which is just as nice as the original. GAHH has approved shops in Tampa they work with that can install the top. I also have a 99 cab, so if you want to see how it looks let me know.
Eric
