Hi Folks,
Ive tried searching for this without much luck. My Oil temp gauge stops working occassionally or jumps up into the red as if its shorting out or maybe the sensor is on its way out.. What do I need to replace? Where is it? Any ideas?
Thanks in advance!!!
Just to add to this. It will say "Oil level monitoring failure" So I assume its the sensor but Ive been wrong here before.
