Will the ECU relearn regardless ?
No, you will need to remove the battery connection for at least a couple of minutes to reset the DME.
This will start the relearning process.
I'm going to install a new MAF sensor. I'm curious if I should disconnect the battery or just install it with out disconnecting the battery?
Assuming the one you're taking out has failed in some manner disconnecting the battery will result allow a quicker ECU learning process starting from the factory default parameter.
How many minutes? Do I disconnect both positive and negative?
As I said in my previous post...
