Found specs for 18-21 inch wheel. I didn't see one listed for a 22 inch wheel. It looks like the overall diameter (for the 285 45 22) will be about 3 inch taller than a stock 18 inch wheel/tire. My current setup is about .80 inch taller compared to a stock 18 setup.
Edited by profusion
Usually you do not want to change your rolling radius by more than 3%. Changes that are larger can affect ABS, PSM, and NAV.
That;s what I thought. I just asked because I saw a great deal on the tires locally. Thanks!
