I have had this noise going on for months. The car: 2003 C2 Tiptronic. The problem: In first gear or reverse under moderate to hard acceleration there is a noticable "tink" or "tink-tink" metalic creaking noise when you start moving from a stand still. The sound is the same as when you crack a lug nut loose. I have removed and retorqed the wheels...It seems the more I remove the wheels, the worse it gets. This final time I took some high temp greese and put it on the five contact points on the hub. OK... it made it worse. I assume the wheels are slipping on the hubs. The design of the Porsche lug bolt has a floating inner ring that makes contact with the rim. This ring has play in it (side to side). So, it seems possible the rims could slip on the hub a little to make these "creaks" I hear. Anyone else have this problem?? Anyone have a fix for the problem?? Thanks!!
