Hard to say but it sounds almost like secondary ignition leakage from a coil. Does the vehicle run ok with no check engine lights. I must admit though that my ears are rubbish.
That doesn't sound good at all. I would pull your oil filter and see if you have any signs of carnage caught in there. If you see metal in there, you know you're in for a tear down, if not, you've only lost less than half a quart of oil.
