For the first time I had a jack slip off the jack point while lifting. Just did not center it good enough. Not a disaster, but I ended up breaking the drivers side bottom black plastic skirt.
I have been searching, but could not find the part number for the driver's side skirt for a 2003 996 C4S.
underbody.pdf If you are talking about the piece just in front of the rear wheel (number 7 on the attached diagram) try 996.504.393.01 for the left side. This is what shows on my PET but the number does not come up on porscheoemparts,com for some reason. If you are talking about the piece in front of this that runs along the door area (number 14) try 996.504.561.00, lists for $47.34.
Thanks much for the help, but I think the name of the piece I need is the driver's side Side Skirt. On my car (C4S) it's black plastic. The jack slid just enough to break the skit mounts.
Do you mean #1 in this diagram?side skirt.pdf
That's it! I think (but am not sure) that the 996 C4S shares the same skirt with the Turbo. Where do you get these great diagrams!
Edit: I am not quite sure if this is the right piece. I am looking for the black plastic piece that might be just below this. It might be called the Rocker Panel Cover too. . . . Thanks again for your help
I think I might need this part: 996-504-363-00-01C-M100 but need to confirm somehow.
Edited by Jon996
