There are heat shields that essentially line the inside of the rear bumper - I need the part number for the lower right one (or all of them, if available).
The center heat shield on the inside of the rear bumper reinforcement bar part number is 986.505.475.00
Regards, Maurice.
I'm talking about the heat shields on the outside of all of the interior bumper pieces - look under your rear bumper and you will see them. There is a center section and two outside sections.
Steve:
I know that there are two side heat shields as I have removed my rear bumper and the bumper reinforcement a few times.
The problem is that the factory parts diagrams don't show or refer to those pieces, as far as I can tell.
I am planning to replace my bumper reinforcement within the next couple of weeks. If the part numbers are stamped on the side heat shields themselves, I'll post the numbers here.
Regards, Maurice.
