Going to replace the failed coolant hoses under the manifold tomorrow for a family member. He just told me his last mechanic didn't install the oil sender due to a suspect unit and it's in his possession, hopefully with the gasket/seal too!
There was a quote on this post: http://www.renntech....428#entry185428 about a cross member being in the way...can anyone speak from experience on this and what needs done? Pulling the engine up? or moving mounts required?
Also, since I don't own the vehicle nor have the owners manual with me yet can you confirm what quantity of oil and weight is required? I see a past invoice here for Mobile 1 but it says 0W40 which I'll assume is 10W40 and just a type...how many quarts/litres should I grab and confirm the weight.
Thanks.
Shawn
EDIT: crap found this useful post on the fill and weight...just need input on the sender:
Edited by rsfeller
