I have a radiator fan that is not working on the drivers side front of the 996. Seems that the covers that are located underneath in front of the wheel wells are missing and there is 2 sensors which operate the fans and 1 has broken away from the wiring. The metal tube shaped one is still intact. Anyone know what the correct part # is for the other sensor and the cover that protect them on each side ? Fan will not switch on and car overheats. Thanks in advance for your help.
