I'm looking at a 1995 993 for sale. I was curious about checking the secondary distributor belt, so I unplugged the primary distributor coil wire to disable it, and the car still ran fine (confirming that the belt is good). As a matter of interest, I then ran the car with only the primary distributor enabled. It still idled reasonably smoothly, but would "pop" every 4-5 seconds, almost like a small backfire. With the secondary distributor back in the picture, problem went away. Is this normal, or is something wrong?
I think it's normal. The odd backfire could be caused from the secondary voltage leaking and causing a misfire. If you purchase the vehicle and it has the black plastic shields installed on the dist. caps, remove the shields and inspect the cap carefully for carbon tracking and install the dist. housing vent kit if not already done so.
