I connected to D13 on the DME for TPS. There are actually 6 different cables including:
D12 - Ground Pedal Value Sensor 2 [Green/Red]
D13 - Signal Pedal Value Sensor 2 [Green/White]
D14 - +5 Pedal Value Sensor 2 [Green/Black]
D7 - Ground Pedal Value Sensor 1 [Green/Grey]
D8 - Signal Pedal Value Sensor 1 [Green/Yellow]
D9 - +5 Pedal Value Sensor 1 [Green/Violet]
For some reason, my data logger shows actual values from 7.966v to 8.258v, rather than something in the 5V range.
Does this sound right for throttle position voltage on pin D13?
-td
