Hello, I have a 2002 996 Targa and get a very loud grinding noise coming from the fron the car when I turn left or right while giving it gas in turns, but when I turn through corners and do no give it gas their in no noise! Also if I accelerate hard from a standstill it also makes that same noise when turning. Do is this a sign of a fron wheel bearing being shot? I have check the front suspension and everything else seems to be fine. thanks
did you find out what the problem was, I have the same noise only in the rear
