A change in my life!!
I am asking before I am touching, so that (hopefully) means that I do not have to replace the cover.
How do I take off the side mirror cover? I have found one screw, but I do not want to put too much pressure on it.
How should it be done?
Regards, frank
Hi Frank -- I recall Loren posting the instructions on how to do this and a few people commenting -- I forget the exact details but if you search the forum you'll find it.
Good luck and be sure to let us know how it goes.
Update: Here's the thread:
Edited by odix
Hi Odix,
Thanks a lot for your help.
This post is actually about accessing the rear of th mirror (glass side). I was referring the the cover in front of the mirror. Is it possible to remove this as wel?
Regards, frank.
should
Update: Here's the thread: http://www.renntech....__1#entry166513
Hi Frank -- the entire mirror does come off. The info/instructions are here somewhere...
When the mirrors are closed (pulled-in close to the vehicle) I think you can see more of how to disassemble. Some other folks who know a lot more about this may have time to comment later.
Edited by odix
