I just installed the B&M short shifter in my 2001 Boxster S, and I love the feel. I do have a few questions:
  • There is a creaking sound that seems to be conning from the area where the shifter cables attach to the shifter. Is this normal? Should I lube the connection?
  • Before installing the cables to the shifter, I marker them for easy installation. After installing the short shifter, I still have some slack in the cables. If I tighten up the cables and remove the slack will it affect the shifting? Right now it shifts just fine, but I would like a little less play in the shifter.
Thanks for the help.
There shouldn't be any creaking sounds coming from the shifter.
Something is rubbing. Probably a cable.
Adjust the cables so there is no slack.
You can then, if needed, after adjusting the cables, adjust the neutral position of the shifter.
Happy Boxstering,
Pedroo
Thanks, I'll give that a try.
Happy Boxstering,
Pedroo
