My passenger side headlight mount bracket is missing 1 of the bolts, and I suspect the insulator is also missing. Can I get the part numnbers please?
The bolts are used to secure the bracket, when I first encountered the warning signs for the headlights, I noticed the bolts were loose. The one that is missing must have dropped out since it was too loose.
Thanks.
yes, not sure why the diagram only shows one not two (you can see the other slot for the bolt ont he right side of the bracket)
The diagrams are always that way.
item 17 -- 955.631.062.03 tensioner -- US MSRP $8.90 each
item 18 -- 955.631.052.01 fastening screw -- US MSRP $0.61 each
