Hi all
I just purchased a 2006 Cayenne Turbo { big grin } I love it it is beautiful. Trying to learn more about the vehicle. New tires were installed before I brought it home. The previous owner said the tire pressure monitor had to learn the system. I have driven over 200 miles and the tire pressure monitor is still not working properly. How long is it supposed to take or is there something else that needs to be done? Thankyou this is a great forum.
Hello ,
you need setup and learn tyre wireless pressure sensors manually . Here on the forum is link for user manuals where on the pages 85 to 98 you can find how to set up it properly....or you can also have drained batteries in sensors:)
I had still the same troubles with it , but i need check even if is the sensors presented from previous customer, or if the battery are not drained off.
Edited by malbardesign
After rechecking all the pressures and re-inputting the tyre info everything is working fine , at least so far
