2003 996 Cab
CEL came on this evening.
Codes: P0300 and P0304, misfire at #4.
Coil pack(s) going bad?
Diagnosis and input appreciated.
Thanks in advance
2003 996 Cab
Thanks in advance
Mook:
Since it's only indicating cylinder #4, you could fairly easily establish whether or not it's the coil pack by swapping #4 coil pack with a coil pack from another cylinder and seeing if the fault code follows the coil pack you took out of cylinder #4.
While you have the coil pack out of #4, it wouldn't hurt to take a peek at the condition of #4 spark plug.
Regards, Maurice.
