HOW TO: make your Litronic Xenon ( Cutoff-line ) SHARPER !
This DIY is for 99-01 996 Litronic Xenon headlamps/headlights Unlock your headlights by using the tool key (female allen wrench) on the side. Use manuals for help. Unscrew these 2 screws then pull the white box out of the way. Once the white box is out of the way you can see behind the projectors. There should be (3) star bit screws (T-20 with security hole) Make sure to mark the (TOP) just so you don't get confused when you put it back together. Unscrew 4 star bits around the proj
Edited by J_STATUS
  • Like 1
