Hi All,
Noticed today that my roof does not close very wel on my cab.
The top closes completely on my 997s '05, but the fabric stays 'open' just above the point where the driver and rear window meet. I have seen that there is a steel cable that should pull everything in place. I did notice a strange sound yesterday (perhaps a snapping cable?).
I have attached a picture of the problem area. Is this something that can be fixed? Do I need to replace the cable? Do I need to tighten the cable somewhere?
Help is much appreciated.
post-22919-009659100 1282045046_thumb.jp
Regards, frank
Hi Micheal,
This was my guess as well.
Thanks.
Out of curiosity: how much did they charge you for the fix?
When the cables snapped on your cab, did you also experience problems with opening the top?
Mine goes down, but just as the cover should start to move the error ' convertible top not in limit position' pops up on the display.
Regards, frank
