I have a 2001 porsche Boxster with a bad tiptronic transmission and found a low milage 1999 tiptronic transmission, My quaestion is will the 1999 work in the 2001 car and if so which control module would i use the 1999 or the 20001, thank you for the help
I think your engine size matters (so a 2.7 tip would not match the tip from a 3.2)...my understanding is your tip has a part number on it...and the transmission you replace it with must have the same part number.
good luck
Thanks for the reply, the engine in the 1999 has a 2.5 and the 2001 has a 2.7, I will have to get them both on the lift to get the numbers off the transmissions, I have read where some people have swapped different years out and say theres no problem. I know the control modules have different numbers
