Look in the Boxster TSB section - search for "summer". That will get you the TSB titled Summer Wheels and Tires.
That TSB has all the possible wheel, offset , and tire size that are approved by Porsche (and hence will not rub).
The TSB doesn't list anything other than 205/55 225/50 for 16" wheels.
A 245/45/16 would fit without rubbing unless you have extreme lowered suspension. You probably don't want to mount it on that 6" front rim though. A 225/245 stagger would work on stock rims. One of our local drivers was running 275/40/16s on16x9 rims all around to good effect. Fenders were definitely rolled though. This website is very useful for sizing and comparisons:
http://www.tirerack.com/tires/tires.jsp?tireMake=Kumho&tireModel=Ecsta+V710
