I have a 2006 Porsche 997 C2. My radio screen is blank now even though music still plays. The NAV is blank as well. Has anyone had this problem?
Edited by rs911p
1) Check the fuses to start with (under the dash,left foot well), 2) disconnect the PCM for a couple of minutes and check the fuse on the back at the same time, 3) check connectors and wiring, 4) check for fault codes with a PIWIS tool, 5) reprogram with a PIWIS tool, 6) repair or replace the unit. Hope it helps.
