Got a 2001 Boxster. Head Lamps will not come on when I turn to the correct position. All other positios work for their respective lights. Went to the dealer to get the part. It appears the knob does not come with the switch. There is a release you trigger with a flat head screw driver and it pops off. Anyone have details on replacing this switch. I'm assuming this is the solution?
-Thanks,
