My passenger side low beam is out on my 2000 C2. It's not the bulb (swaped with a known good bulb) and it's not the fuse. Any thoughts on what it might be? (High beam works, as does the city light). Thanks in advance! Lennie
Ok did the search - checked the connector pins on the light - appear to be OK. Seemed the switch problem was more of an issue with the litronics than the standard halogens. Only the low beam is out - and nothing "flaky" happening otherwise. I'll check the connectors again. Thanks
