hi i just both a 1997 boxster 2.5 which has clocked about 70k ... the car jerks when the gear changes from 2-3rd ... and there seems to be no power and the engine feels rough... my mechanic changed new spark plugs but the problem is still there ... the diagnostic says cylinder misfire ...
what could be the problem? need help
jay
What "diagnosis"?
Maybe cracked coil pack(s) or plug wires.
Regards PK
Edited by pk2
Swap coil packs and plugs from one side to the other. If you still have the same cylinder missing, its internal. Mine turned out to be a broken spring.(98-986)
