Got a '98 996 and think the newer dot-matrix-equipped instrument clusters looks **** cool (reason enough!). Is it possible to swap my instrument to a newer one and will a Durametric cable & software be able to enable everything needed to make the new cluster work?
I managed to searching my way to find that the older cars have a 26 pin connector while the newer ones use 32 pins. WIth the correct pinout schematics would it be possible to get the correct signals at the correct place or are we talking apples and pears here? The threads I was finding were 5-7 years old so some other solutions might have presented itself since then...
The cluster I'm looking to buy has the following info:
VDO
110.080.019/003
996 641 215 00 70 C
TYP RDW
Thought the 996 didn't get can-bus until '03, and dot matrix from '01. I might mix the info with what was delivered on the Boxster though.
