I'm going to clean my MAF. I hear two things that people uses MAF cleaner and the electronic cleaner. Which one is the right thing to use?
Ok thanks, hopefully this will get rid of my CEL P1128
Don't count on this as a permanent fix. It won't make an old MAF brand new, so at some point you will probably need to get a new MAF. But cleaning the MAF will help you determine if it was the problem or something else before you go out and buy a new part
