My air conditioner blows hot air when it is set to use outside air. Blows icy cold when it's on re-circulate. This happened once before when the car was under warranty and I was told that a flap was slipping on the shaft.
I'm assuming it's the same issue now, so, my question is; How do I access the flaps/shafts? Is this a do it yourself job? Some mechanical skills - short shifter install, restored a 65 mustang, and various maintenance tasks.
Mario
Edited by Loren
corrected title - 2003
1993 996 cab?? Must have been a really early prototype.
Many times these AC problems are an activator/arm coming off one of the flaps. You may be able to see it by taking off the console horseshoe or looking around under the dash.
Thanks, Meant a 2003 996, lost a decade somewhere!
I'll check under there.
Mario
