I have been getting p0102 codes for sometime for my 2000 996 with supercharge. Once I cleared it, it would come back approximately between 2 to 5 days. I read the post and tried the suggestions on checking for vac leaks (no leaks), changing the air filter (change with a new one recently, K&N & I cannot change it back to stock due to the supercharge taking up the space), and recently bought and change the MAF sensor.
I have change the sensor now and the p0102 had been replaced by p0103. Any thoughts?
Dratini
:welcome:
Please try our search next time - these fault codes have been covered many times before here.
P0102 Mass Air Flow Sensor – Below Limit
P0103 Mass Air Flow Sensor – Above Limit
Possible causes:
P0102
- Open circuit
– Short circuit to ground
– Mass air flow sensor
P0103
– Short circuit to B+
– Throttle jacking unit
