I just added some windshield wiper fluid to my car and it came out quite rapidly. I could not see where it was coming from. Any ideas what the problem could be before i start pulling everything apart?
Kristian
Either you have a leaking hose, cracked tank, or a bad pump motor.
You will need to remove the left front wheel, then the wheel well liner. The equipment is up at the top right of the wheelwell.
