I just replaced the driver's side window regulator on my 2001 Boxster. Afterwards, my airbag light has been on and will not go off. I had to remove the driver's side airbag to gain access to the window, however, I made sure it was reconnected properly. I'm assuming I just need to have the light reset. Woud anyone be able to assist with this issue?
I live in Enid, OK close to Oklahoma City, OK.
Thanks!!
I have tried to reset this with my OBDII but I had to go to the dealer and have them do it. Ask Loren here as well he will be able to confirm for you. I'm pretty sure this is a dealer rest unless you have the PS2 software since it's a very important safety system.
Good Luck
