I understand that the serpentine belt should be replace every 60K miles. But is there a time limit for low mileage cars? Like do you have to replace it in 10 years if the car is still less than 60K miles?
I haven't seen any official time limit put on the serpentine belt, but since it's made of rubber, and rubber deteriorates over time, I'd think it's a good idea to replace this relatively cheap item if you're pushing 10 yrs on it. If it fails on you, you're gonna be left stranded.
I replaced mine at around 50k miles and 6 yrs just to be safe, and then kept the old one in my car's trunk to use as an emergency spare.
Good advice!
The recommended replacement time (low mileage cars) is the same as for spark plugs: 4 years. Hope it helps.
