Trying to remove the steering wheel and I’ve gotten as far as loosening the nut indicated with the arrows. After giving the nut a few turns so there is some space in the threads, the next step is to pull the steering wheel out a bit. But it won’t budge. What am I missing? Anyone know why it won’t come out?
Place the steering wheel in the straightforward position, loosen the nut completely, place the nut back on the column and tighten the nut 3 turns, pull the wheel quick and alternate left - right harder backwards with both hands, the wheel should come off now.
