Battery was disconnected to repair a horn problem. Windows will now not roll fully up ( will only go up about 3/4) when top is closed but will roll up fully with top down.
Tried doing the window standardization procedure in Bentley book. With top down I rolled window up and held for a count of 30. Book seems to indicate this is done with the top closed but window will not roll fully up in that position. This procedure worked for me before.
Is there a time limit after battery disconnect and doing the sync? It's probably been a couple of days since battery was disconnected/
Am I missing something?
BTW - Is this mentioned anywhere in the factory supplied owners manual? I can only find a short mention in the Bentley book.
Thanks.
Bill
Edited by UtahWJR
Thanks.
Bill
Bill:
Is it possible that the microswitch inside the latch assembly (the one [of two] that controls the 4" drop down when you pull down the latch) is malfunctioning or possibly sticking?
If so, the windows will not stay all the way up but will retract 4".
Try poking your finger or the eraser part of a pencil into the part of the latch assembly where the latch normally locates when closed while you try to close the windows all the way up and see if you get an intermittent result.
Regards, Maurice.
Grabbed the top and pulled it closed instead of just allowing the motor to close it and now thevwindows go all the way up. So the problem is the microswitch. Are theaseveasy / cheap to fix?
Bill
Bill
Bill:
Easy to access and replace, and relatively cheap part.
There are two microswitches in the latch receptacle assembly. There is one on the left side of the assembly (has a large plunger that juts out when the latch is open). That one controls the 4" window drop that occurs immediately when you pull down the latch to open the top and that is the one that is probably faulty in your case. Sometimes the plastic part of it just bent out of shape and it can be "revived" into the right shape with a heat gun. (There is another one on the right side of the assembly, and that is the one that allows power and activates the convertible top double relay.)
To gain access to the microswitch you have to remove the latch plate at the center of the windshield frame. Pop out the two little black plastic "eyes" by carefully prying them off with a very small flat blade screwdriver or borrow one of those "orange sticks" that women use on their fingernails to pry them out. Remove the small torx bolt that you will find under each one of the two eyes. Remove them and then pull down the latch plate carefully until you can see and access the wires for the switch and for the light. Unplug the wires and the latch plate will come off.
Regards, Maurice.
