Anyone have any tips for removal of the front diff on an 05 Cayenne s? was very noisey needs replacement.
I assume the entire front carrier must come out. Treading new ground and looking for tips.
The factory manual instructs you to support the engine from above, lower the front subframe and squeeze it out through the center section of the subframe. It is a tight fit but it is possible. Or you could remove the entire subframe and theres a lot of extra work to accomplish that but it would make putting the new diff in easier.
